ldaa
- May 1, 2015
Hi Guys, I recently bought a pair of SR125i's on ebay. First off, I love them, they're easily the best cans I've ever owned. They were a bit damaged during shipping, the seller left them in the thin cardboard box and they got crushed or something in the post. One phone had a rattle to it (creased diaphragm), I complained to the seller and didn't get far because ebay is useless etc..
I ended up fixing it by blowing into it from one side then the other and it worked great for a while... Eventually the rattle came back and I tried fixing it in the same way and it just got worse
It ended up being really awful and ratttling then almost silent with the occasional rattle. Eventually it became completely silent and I can't fix it
. I tried taking it apart, I couldnt get the front grille off but I removed the mesh and removed the creases from the back. Still no luck though.
Does anyone know if it's repairable? I've searched the forums and can't find anyone with a similar problem (complete silence not just rattling). Have I broken the wire leading to the coil?
I'm really bummed these were amazing cans, if it's not repairable does anyone have another broken pair of SR125i's I can buy one of the cans from?
I hope someone can help, thanks folks!
![frown.gif](http://files.head-fi.org/images/smilies/frown.gif)
![mad.gif](http://files.head-fi.org/images/smilies/mad.gif)
