ib1dance
- Dec 7, 2008
Hey ,
I am wanting to re-cable my igrado's with a stronger ,better quality cable.
I thought it would be simplest just finding a Good quality headphone extension .Like a 3.5mm > 3.5mm headphone extension with cable that could be split @ one end .So I could cut one of the jacks off,split the cable and wire it into the iGrado's .Saving me from also buying a extra jack to wire .
But I'm having problems finding such a cable that is decent quality and is split-able .
I found this
http://www.amazon.co.uk/Hama-Headphone-Extension-Cable-3-5mm/dp/B0009V8W78/ref=sr_1_6?ie=UTF8&qid=1304268515&sr=8-6
Though the cable doesn't look much better than the one already on the iGrado's .
Anyone know of anything of better quality,split-able that's available in the UK with a jack @ least on one end ?
Is the only way buying a separate cable,jack plug etc .
Alternatively a address for a UK based shop that sells rewire-able headphone Jacks ?
I found this
