Dan the audioman
- Sep 16, 2003
I am looking for an extenal hard drive for my IBM R40 laptop. I would like it to work very similar to how the iRiver ihp-120 works. I am looking for something around 80-120 gigs. Nothing special.
Basically what I would like to do is have another C drive that I can just leave hooked up. And I would like to be able to link folders that are used by certain programs to the drive (EAC is an example of a program).
(For Example: I would like to hook up the outgoing files folder of EAC to go to this external hard drive. That way when I rip all of these wav files in EAC, they dont fill up my actual laptop hard drive, but they go to the external one.---is this possible??)
I've been snoopin' around and I came up with a few:
LACIE 80GB USB 2.0 HD 7200RPM PORCHSE DESIGN
IOMEGA® 80GB HDD USB 2.0 EXTERNAL DESKTOP HARD DRIVE
Maxtor OneTouch 80GB 7200RPM USB 2.0/1.1 External Hard Drive
MAXTOR 120GB USB EXT HD ONETOUCH 2MB 7200RPM
If you could take a look at those few that I picked out it would be very helpful. The MAXTOR 120gig and the LACIE 80 gig look like the best deals but I don't know which one would best fit my criteria.
Thank You very much.
Best Regards,
Dan
Best Regards,
Dan
