Benno1988
Anyone with more of a clue help here.
Have a Topping D50S connected to a SMSL SP200
Now if no music is playing, there is some static noise. If I move my mouse around, that noise changes with the movements.
I held the RCA cable between the DAC and Amp off to the side, no change.
The D50S has a USB power lead and a USB data lead. Both plugged into the mobo at the back. Which is likely the culprit? To me it seems like the signal is being fed to the Amp like that. I'd have though the USB Data would not be phased, reasonable to assume its the USB Power?
Will try power it off a phone charge plug and see if that helps, and report back.
