drew.haynes
- May 22, 2006
Ok, so here is the deal... Original configuration on the DT770 has right, left, ground enter the left ear. The driver has 3 solder points and right, left, ground EACH attach to one. From there, jumper wires run from the right and ground through the headband to the other driver. First, I recabled with mogami 2534 in the STOCK configuration... WORKED. Then I decided to go dual entry. A ground and left signal wire go to left driver, while a ground and right go to the right. The grounds merge at the 3.5mm jack. Now the right driver plays and the left is DEAD silent. Does anyone with Dt770 cabling experience know what could be wrong? I can't figure how I COULD have blown the driver, doesn't even seem to make sense. I don't know why the right signal ORIGINALLY is soldered onto a 3rd point on the left driver, prior to jumpering to the right. Does the left driver somehow require that all 3 tie to it, while the right driver works with only signal and ground? Really desperate here. Frustrating!
