vwap
Padawan.
- Dec 4, 2002
Hi All,
So I recently went on a DIY IC adventure... Bought some Canare GS-6 and some Canare F-10s (All they had around or something..).
Anyhow, so I soldered the signal wire to the center connector on all the RCAs and folded the ground over the shield on all four... It's continuous on each end of the RCAs, so it should all be happy, right?
But I plug it in and get no sound out of either cable.. not sure what I did wrong?... Any help is appreciated. If more info is needed, let me know.
Thanks!
Thanks!
