redshifter
High Fidelity Gentility• redrum....I mean redshifter• Pee-pee. Hoo-hoo.• I ♥ Garfield
- Aug 12, 2001
i have a sony dd9 walkman--top of the line, dolby b&c, full titanium case, dual quartz locked motors, etc. bottom line is, this walkman rocks, and sounds better than many home decks i've heard.
now the real sad and weepy part of my story:
since i bought it used the volume control has had static, i.e. it is dirty. i bought this spray from rat shack called "tuner control", which you spray into the dial contact to clean. i tested it on an old equalizer and it worked great. so i tried it on my dd9 walkman, and now the motor won't work. i think too much spray squirted in when i shot a split second squirt into the volume contacts.
anyway, does anyone have any advice on how i can fix this? can i take it apart and dry the motor? please help.
