pojen_h@hotmail.
- Feb 18, 2006
After researching, I fininally nail down the three DACs that I "think" will fit to my system:
My setup:
My origional plan was to get DA60 + DA-Ah(unmod). After e-mail Eddie (person in charge in kiydit), he mention that DA60 might not be as good as Citypluse DA7.2x
(by the way, I would like to thanks Eddie to spend so much time e-mail me.)
I was concern with the remote and headphone out on the DA7.2x. (I believe the simplier it is, the better it gets.) What should I do?
Given the price, which one will you chose?
Links: (head-hi threads)
Any feedback is apperciated.
PoJen
- Citypluse DA7.2x(~USD: 350)
- Lite DA60 (~USD: 390)
- Lite DA-AH(unmod) (~USD: 150)
My setup:
- STAX SRM313+SR404
- Listen to classical music (mainly piano concerto), opera, and Japanese-Pop
From Eddie: D-7.2x can be switch off fsx2 and playing just as input spdif. Once you swith on fx2 then will oversampling itself and that is why super sharp and High defination. DAC-ah is good choic for Vocal and it will suitable to your Japense pop song. Dac-60 is not as Hi-Fi as D-7.2x will do. |
from Eddie ("it" here referes to DA7.2x) It is using cs-8416 input chips Da-chip will be PCM-1796 both support 24-192khz. It is very HI-FI in and detail and even for Classic no problem |
- DA60 is indeed a beautiful DAC with proven performance. (DA60 is similar to Monarchy DA24)
- DA-Ah (unmod/mod) is a popular DAC here, and recommend by many members. (unfortunally, I didn't find someone use DAC-Ah to feed a STAX system)
- Citypluse DA7.2x is a new model with nice spec/first impression,(DA7.2x looks similar to CEC DA53) and fetures that I don't want.
- A new 7.2x
- DAC-AH
- Which Lite DAC for me(thread regarding DA60)
PoJen
