dimm0k
- Jul 31, 2007
I want to cut out a hole in the Sony MDR-V150 ear cups and was wondering what the best dremel bit to use would be. I know getting a hole saw would be easier, but I prefer going the dremel route. Should I use discs to cut or those drill-like bits? The ear cups have a small dome shape so I was going to put the ear cup on the leveled side and screw a nail in the middle of the dome to hold it in place while I cut. Is there a better recommendation to holding it in place?
