drogba
- Oct 8, 2010
hey guys got a very noob question here for ya's
i just bought a lehmann audio black cube linear headphone amp (pro version - which has the XLR connections) and i want to connect it to my soundcard (Auzentech X-Fi HomeTheater HD).
The soundcard has the following outputs;
HDMI Output
HDMI Type A Plug: Output HD video and HD Audio to HDMI and HDCP compliant Digital TV or AV Receiver
Digital Output
RCA/TOSLINK Combo Jack: Can connect to external DAC, AV Receiver, and Decoder through a 75Ω Coaxial cable or optical mini cable. Can play S/PDIF Stereo PCM and Dolby Digital AC-3, DTS등 bit-stream content.
Headphone Output
3.5mm(1/8”) stereo mini-phone jack: Includes an independent Headphone amp and can activate at impedance 16Ω ~ 600Ω headphone or earphone. Also, can be used, when configuring a Stereo system (not using the Analog I/O cable) as a Front Line Output.
Analog I/O Multi Connector
D-SUB 15 pin connector: Connect the Analog I/O cable bundled in this package and use it for Mic input, Line input and as an 8-channel line output Jack.
what are my options here guys? im clueless.
Any guidance would be awesome! thanks so much.
HDMI Output
Digital Output
Headphone Output
