Idsynchrono_24
- Sep 22, 2005
Hey guys, the sound in the right driver of my SA5k's has gone out. This is not the first time this has happened to me, I owned a pair of SA3k's that had the sound go out in the left driver and I had to return them to Sony. This time, I can't do the same thing because I bought these off of a Head-Fier... I've traced the problem to the headphone jack, right where the rubber sheath ends, the sound would cut in and out when I wiggle the wire, it worked for a little while, I could listen if I sat still, but I knew it was only a matter of time before it died completely. So what is there that I can do? I really could use the help, this is the second time this has happened, and Sony's QC is really beginning to tick me off. Thanks guys.
Catch you later,
Id
Catch you later,
Id
