Eggaboy
- Nov 4, 2014
Hello guys I am quite desperate and need your help
A few weeks back I was watching a video with my DR 990 PRO (250 Ohm) as the sound suddenly broke down, with broke down I mean I wasnt able to understand anything at all, some sounds came threw clearly I was no longer able to understand the persons talking in the video. After further inspection i noticed that if I inserted the 3.5mm jack just right into my Sound-Card I was able to get the headphones working again, but only Mono-Sound. Either left, right or both(still mono).
So I made a Stereo-Sound test: When the sound should have come from the left side there was none at all. When the sound should have come from the right side, I heared it on both sides. I played around with the Sound-Card and the 3.5mm jack while doing the test and than the Sound only played on left side, the right side or both at the same time (while sounding correct).
I don't know what the problem might be would be really nice if someone would know how I could fix this, because they are no longer under warranty, I can't really afford a new pair of headphones as I am a student :S
Obviously feel free to ask me any questions if I wasn't clear enough or you need any further information.
Thanks in advance, Eggaboy.
