f00fighters
- Dec 4, 2007
I am trying to figure out how to get the optimal performance from my apogee duet as an amp. My main source of information other than the FAQ, has been from this thread.
I have updated recently to the latest apogee drivers labeled "september 2009 Snow Leopard" update. I am using a Mac Pro tower.
I disabled Apogee Maestro from startup in the Apogee Maestro preferences. I'm not entirely sure how to even use it. I have never adjusted any settings in there. Every time I go into Maestro Control, the title of the window says "Maestro Control: Untitled*" And whenever I exit, I never save.
From System Preferences I went to "Sound" and I selected Duet under the Input tab, as well as under the Output tab. So all volume control is controlled by the duet.
I went into Audio MIDI Setup, while iTunes was closed, and selected the 96000.0 Hz and 2ch-24bit under the output and input tabs for the Duet. Then I closed Audio Midi Setup.
Then I open iTunes, and play my music. 98% of my music is formatted in Apple Lossless from CD ripping.
Am I getting the most from my duet as an amp with what I'm doing? Am I doing anything wrong? Does Audio Midi Setup need to be open while iTunes is running so that it is up-converting to 96 khz? I'd appreciate any help or suggestions.
