chych
The butter knife's second victim.
- Jun 21, 2001
Yes, help me, a total idiot in DIY/electronics
I recently got a ceramic iron and within 10 minutes, I ruined the tip (!!!). Stupid thing won't take solder anymore... anything I can do to make it work again, clean it some way? I did buy a spare tip just in case, but I don't want that to die really quickly. How should the tips be used anyway, I seem to never get the tinning/cleaning right. My 45watt iron does not get this problem though, I guess because it gets so hot it will take solder no matter what.
Also, how would I, say, install a power outlet? I opened mine up that I am planning on upgrading with a silver plated outlet and I saw only 2 wires... one hot and one return. What is the ground? There is no ground wire, is the receptacle that holds the outlet the ground or something?
Also, I'm not sure what the explanation would be for this, but out of the outlet I am planning to upgrade, my MG Head amp works fine out of. However, my APC surge protector reports a line fault. When I plug the MG Head into a different outlet (which I opened up and looks wired the same as the previous outlet), I get that evil hum in the left channel... though my APC surge protector does not report any line fault. Any explanation for that
Using a "cheater" plug to remove the ground does not help remove that hum...
