AverageGuyNC
- Feb 5, 2017
Hi! I wanted to upgrade my headphones on my computer that get daily use.( Music on YouTube and DVDs mostly). After looking for a setup with good quality and value, I got a Hifiman he400i with an O2/DAC that I really enjoy.
I put in a kinda low bid on some Fostex th 900 ($810) on Ebay and won! but here's the dilemma; the seller reterminated the connection on the factory cable and put on 4 pin xlr Neutrick balanced connector and my amp uses 1/4 inch out! The adapters for xlr are too pricey for me and I decided on switching it over to a 3.5mm so I can use it on other things as well as my amp and ordered a Viablue 3.5 connector after the praise I read on here about them.. But I have even considered buying another amp with balanced out. the oppo ha1 that he used worked great he said but its 1,200!
So for an inexperienced person, what do I do? Buy a 2nd amp (would spend a few hundred maybe), or take it up to a local guitar store and have them solder the 3.5mm on? Ive heard that an O2/dac will work fine with the Fostex, are there any others that would really make a noticeable improvement on them? Oh, and they were upraded with Lawton leather ear cups. And I have Amazon prime music streaming that I'm considering using now on my pc.
