Originally Posted by BIG POPPA /img/forum/go_quote.gif Pick your poison and go from there. They both have their strengths. I prefer tubes. That is just me.
X2
You can easily change a tube amp's sound by changing tubes (tube rolling).
SS are not easily modified.
Tube Amp : easy to fix/mod (if P2P wiring is used), beautiful tubes glows, tube rolling (can be pros/cons), heavy, certain tubes can be very expensive and rare to find, cheap tube amps sounds mediocre (more metal = more $$).
Solid State : generally cheaper, smaller, lighter, requires little maintenance if any at all, not as beautiful as tube amps
