Hello all, looking Amplifier
Feb 23, 2017 at 4:55 PM Post #16 of 50
  Many people don't like tube amp's either.
Because Tubes color the sound and are not a reference/analytical sound.
If you want something that is analytical either look at o2Amp or maybe an Asguard 2..
There are lots of cheap offerings too which can power heavy phones, like the SMSL VA2 and FiiO E9, etc.
The Asguard 2 is considered warmer than version one. Not sure how much warmer a Valhalla 2 is compared to the Asguard 2. This makes the choice a bit more difficult. But Since the DT880 600 is quiet neutral, a bit of coloring would not hurt. I am not the 100% analytical listener. =)
http://www.ayonaudio.com/ayon/why-tube-amplifiers.html
Hmm,, Tube still.
Feb 23, 2017 at 9:14 PM Post #18 of 50
  I wonder, What I am saying , does it make any sense? Will some amplifiers give a bit or more bass and another less?
Some amplifiers can have less bass due to distortion, most commonly through an output impedance higher than the load nominal impedance. Some amplifiers by contrast can have more bass by not distorting, or just by having a blacker background as the lack of what you thought is inaudible high frequency noise on some amps is no longer there to affect what bass you can perceive. In the latter example the bass isn't measurably higher, your ears just hear it more easily.
Similarly some amps can have more bass through distortion. In some cases the impedance mismatch can boost bass. In other cases deliberately introduced distortion through bass boost or what counts for "tubey," ie, rolling off the high frequencies, which like the noise reduction, makes bass more audible, except in this case the high frequencies are trimmed off (if not some lower frequencies boosted as well).
In the end what you should go for is an amp that won't distort badly or at least its distortion pattern doesn't make it bright, but still, one that piles on that distortion rather gently, in other words, choose a Schiit or a Meier over the O2 (all have THD measurements supposedly below audibility but push them hard and the first two have less of a tendency to scratch your ears; don't expect it to sound like what people look for in tubes though).
Feb 23, 2017 at 10:06 PM Post #19 of 50
That's quite funny as the most expensive headphone rig to date is full of tubes.
Feb 23, 2017 at 10:16 PM Post #20 of 50
Well that isn't surprising. The more I read about audio the more I understand that the most expensive stuff is just for people with too much money and specific tastes and doesn't seem to at all be about analytical sound quality.
Feb 23, 2017 at 10:25 PM Post #21 of 50
No need to be expensive. I'm a tube convert after hearing Saga which is much more musical sounding than Asgard 2 it replaced.
Feb 24, 2017 at 3:23 PM Post #23 of 50
I jump into this discussion about tube or not. I read that tubes produce noise , as does the transistor / IC amps, but the tube makes the noise somehow pleasing to the ear. I have no experience yet. I ordered the Shiit Vahalla 2 today. Hope to get it by the end of Monday, or sooner.
Feb 24, 2017 at 3:25 PM Post #24 of 50
Interesting. I don't like high volume. I rather keep them intact and prevent any hearing aids.
Feb 24, 2017 at 3:59 PM Post #26 of 50
I'm the same way, and many headphones don't need any of the power that amp's provide.
There are many lower impedance headphones.
No way back to lower impedance now.
Feb 24, 2017 at 9:34 PM Post #28 of 50
Well can you tell me what is too much money ? The specific tastes that you disagree with? Why is analytical sound what someone should prefer? Please don't say that you want to hear what the artist intended as that is not possible as it got shipped off to mastering and adjusted there.
Feb 25, 2017 at 12:50 AM Post #29 of 50
No,
I want to hear things the way they were recorded and they way they are meant to be heard.
I don't want to color or distort the sound, but I think that this point of view doesn't have only one answer, because reproduction of audio bitness is just one step.
Feb 25, 2017 at 2:10 AM Post #30 of 50
You chose wisely OP.  Valhalla 2 is fantastic for high ohm headphones.  It was the first amp that had me go WOW!  Other amps are different flavors of the same.  OTL is amazing.
