When wearing headphones (tried k371, 7510, dt770) I can hear the heartbeat which is annoying during quiet parts and when making music. How do I fix this?
Heartbeat sound when wearing headphones
- Thread starter foniak
ruinedx
- Sep 11, 2016
Have you tried an open-backed headphone like the Sennheiser HD599?
https://www.bhphotovideo.com/c/product/1280823-REG/sennheiser_hd_599_open_around_ear.html
Or do you need the sound isolation of a closed back? The open back otherwise could potentially relieve or reduce the issue.
NA Blur
- Feb 8, 2011
Yeah open headphone will keep your eardrum from becoming a stethoscope. Think about it...you seal a membrane ( i.e. eardrum ) and due to its proximity to your veins and arteries in your neck you are essentially hearing the blood flow.
Loosening up the seal will help or going with a slightly open headphone is another great suggestion.
bagwell359
I have all open headphones and a very loud artificial aortic valve and I never hear any of it.
I tried the HD650 once, returned then because they had an insanely smooth sound to the point it was annoying, i needed a more neutral sound as a producerHave you tried an open-backed headphone like the Sennheiser HD599?
i dont remember about the heartbeat sound tho. should i buy the hd600? heard its more neutral. but i do enjoy the focus that isolation gives me yeah, its jsut the heartbeat ruining it
which ones would u recommended?Yeah open headphone will keep your eardrum from becoming a stethoscope. Think about it...you seal a membrane ( i.e. eardrum ) and due to its proximity to your veins and arteries in your neck you are essentially hearing the blood flow.
i recommended going all in and buying an lcd-x, however heard they are heavy as hell
ruinedx
- Sep 11, 2016
The hd600 is very neutral yes. Hd650 is known not to be.I tried the HD650 once, returned then because they had an insanely smooth sound to the point it was annoying, i needed a more neutral sound as a producer
I had recommend hd599 because it was cheaper and more in line pricewise with other headphones you had bought.
NA Blur
- Feb 8, 2011
HE650 and HD600 have very similar sound signatures. It's going to be a big waste of time and money to go with the HD600. I've owned both and prefer the HD650 as it has better treble detail. Other than that they sound identical to me. You can dig around Innerfidelity and see the measurements to convince yourself of this too since you have not heard them side by side.
You say you are a producer so you may need a slight seal to extract the details. Perhaps something like the Aeon Flow Open would suffice? See if Dan Clark Audio has one for sale and see if you can audition it for a week.
Mink
Well since the consensus in this thread is that open-back headphones are the way to go to stop this pulsing heartbeat sound and you don't like the HD650s I'd suggest the open variants of the closed ones you own: Beyerdynamic DT880s and AKG K612
ruinedx
- Sep 11, 2016
Would also say from a production standpoint the HD800 [non-S] are pretty ideal open headphone for "seeing through the mix" but these are quite the price jump (even used) from any of the headphones mentioned by OP.Well since the consensus in this thread is that open-back headphones are the way to go to stop this pulsing heartbeat sound and you don't like the HD650s I'd suggest the open variants of the closed ones you own: Beyerdynamic DT880s and AKG K612
What about the LCD-X comapred to HD800? my concern is that its too heavy.Would also say from a production standpoint the HD800 [non-S] are pretty ideal open headphone for "seeing through the mix" but these are quite the price jump (even used) from any of the headphones mentioned by OP.
ruinedx
- Sep 11, 2016
The HD800 weighs half as much as the LCD-X, if thats what you mean?What about the LCD-X comapred to HD800? my concern is that its too heavy.
yeah the lcd x being heavy concerns me to spend many hours with it producingThe HD800 weighs half as much as the LCD-X, if thats what you mean?
will technology allow for an lcd x thats ligther?
ruinedx
- Sep 11, 2016
LCD-MX4 is about 30% lighter than LCD X but both heavier than hd800yeah the lcd x being heavy concerns me to spend many hours with it producing
