JayB18
- Nov 18, 2006
Im looking for a portable amp/DAC combo to go with my grados and AD700. Would this amp match these headphones well?
Originally Posted by JayB18 /img/forum/go_quote.gif Thanks but I dont think I would want to swap opamps. Which amp has better soundstage/separation. Is the DAC much better on the iBasso D2. Does the ibasso D2 have a website I can order them from because I couldnt find anything. Thanks. |
Originally Posted by vvanrij /img/forum/go_quote.gif Headphone addict, what opamps would you recommed? Any specificly good for Grado? (getting the 325i's next week) |
Originally Posted by HeadphoneAddict /img/forum/go_quote.gif I said "my iBasso D2 (for the same price) drives the Grados as well, and the DAC renders more detail and air and ambience to the music". So, the more "ambience" gives it a better/more realistic soundstage. And, the D2 separation is better, as implied by when I said more "detail and air". And, the D2 will power the Grados with the stock opamps just as well as the Lyrix. You only need to change opamps if you want more power, or want it to sound as good or better than a $500 Pico (depending on your ears and tastes, and it is also possible to make it sound worse). The D2-Viper with removable opamps were a limited edition of 100 units, so the only way to get one is in the FS forums. Since you don't need to change opamps, the newer version with soldered in opamps should be found at Products (soon if not already listed as available). Hope this helps. |
