Spad
- Dec 11, 2001
Polk's SDA is actually a lot more complicated that this thread might lead one to believe. Nspindel wasn't trying to do more than give a very general overview, which he did quite well actually.
As best I recall, this is how the process was explained to me many years ago:
In the Polk SDA SRSs the actual SDA section, not counting the considerable electronics involved, consists of two vertically aligned rows of four 6.5-inch mid-range drivers each. Between these is a row of four vertically aligned 2.5-inch tweeters. The innermost row is fed the inverted 100 to 1000 Hertz signal from the other via the connecting cable. This is why the speakers are designated left and right. Obviously this alone isn't sufficient to account for the system's effects, but--at least so far as I know--Dr. Polk kept the electronics (which fill an entire amp-sized bay) pretty close to the vest.
The speaker systems are 64-inches tall and weigh 155 pounds each. Polk recommends setting them up with at least 5.5-feet of free space to the outside of each speaker and that the distance between the speakers and the listening position form an equilateral triangle. They come with spikes sufficient to reach most sub-floors along with an 18-inch metal rod called a "bass brace." This screws into the back of the speakers about four feet above the floor and attaches to a wall stud.
The cabinets are 22-inches wide, so if you want to sit 10 feet from them the ideal setup would require that they be placed along a 25-foot wall--something not easily found in most homes. This is what we mean by hard to place, and that they tend to dominate a room. In reality, anything even close to the recommended setup gives pretty amazing results. In the article I mention above, the reviewers were able to separate them by a mere 5-feet. I currently have them about 8-feet apart and sit 10- to 12-feet from them and they sound terrific.
Their performance is even more dependent on program material that most systems. A mono source or one having very little channel separation renders the SDA effect useless. OTOH, well recorded material can be, and often is, astounding. Close your eyes and the speakers seem to disappear and along with them the walls. A symphony orchestra isn't simply created between the speakers as with most other systems. It arcs across the front, including the aforementioned free space, extends well beyond the back wall and curves down the side walls towards the listener.
Sounds like load of horsedoody, doesn't it? All I can say is read the reviews of the Polk SDA SRS (not simply SDA) by the most reputable audio writers of the time. And this is the key phrase to remember: "of the time." Today even a modest 5.1 system--including some made by Polk--can equal or better it's spatial performance. The magic was that all this was done by a legendary pair of speakers, not the bevy that many of us use today.
Sorry to be so windy.
Originally Posted by AdamWill I just read this thread, and there's one thing in the initial post I still can't shake off. I still can't figure out why this system requires one speaker to be labelled Left, and one to be labelled Right. If they each output a negative image of the other, why does it matter which one is left and which is right? |
