GearMe
- Feb 17, 2013
Is there another portable amp that I could use as I cant afford the E18 at the moment.
If you want a portable DAC/AMP, the Fiio E07K should work and save £50 over the E18. Down the road, you can add the desktop based E09K amp/docking station for additional power for the 300-600 ohm headphones that you'll eventually be buying.
http://www.amazon.co.uk/FiiO-E07K-Portable-Headphone-Amplifier/dp/B00A9LHLQ6
ClieOS has done some portable shootouts
http://www.head-fi.org/t/596482/the-sub-100-portable-amps-shootout-11-1-amps-compared
http://www.head-fi.org/t/620775/the-sub-200-portable-amps-shootout-13-11-amps-compared
For a short term, inexpensive solution you could get the Topping NX1 for £28.99...just an amp (no DAC) though.
http://www.amazon.co.uk/NX1-Portable-Amplifier-Headphone-Rechargeable/dp/B00IE2AKD8
