mikeaj
- Jan 10, 2010
To the couple posts above, the big issue is that no two headphones are exactly the same—very much so for two headphones of different models, but also true for different headphones of the same model.
In fact, results out there (which may or may not apply to every headphone, hence more results would be nice) seem to indicate that the difference between different samples of the same headphone is larger than differences seen for before/after of running a signal through the headphones for many hours (burn in procedure).
Also, many times significant differences have been demonstrated when using new vs. old earpads. Do you consider wearing down earpads as part of the burn-in process? The way it's worded and how people talk about it, I don't think they really do.
More or less, when you change more than one variable at once when comparing different things (where more than one is variable known to make a difference), don't draw conclusions about the effects of any individual variable, because you didn't test for that. That's basic experimental science and common sense hopefully.
