Headphones as microphone
post-5406176
Post #16 of 28
boomy3555
some people over in the "Burn-In" threads I've seen actually attach 9v batteries to thier hp's to run current through them during the whole Pink, white,whatever noise thingy so a few volts d/c should be pretty benign
post-5406365
Post #17 of 28
yukihiro
I've used my cheapy headphones as mic's before. Pretty sure plugging the headphones into the mic jack won't hurt them since I don't think they output any type of signal.
post-5406444
Post #18 of 28
John Willett
Member of the Trade: Sound-Link ProAudio & Circle Sound Services
Basically dynamic microphones and headphones are very similar - just a coil of wire attached to a diaphragm wiggling around in a magnetic field.
This was, in fact, how Sennheiser invented the open headphones, when an engineer took two microphone capsules and held them to his ears (but that's another story).
There have been some communications microphones that did the job of both microphone and loudspeaker - switching to loudspeaker mode when your finger was removed from the "mic." button.
BUT
If you want to connect your dynamic headphones to a mic. socket on a PC, MiniDisk, flash recorder, or the like you will need a special adaptor cable. These devices have about 5-Volts of "plug-in power" to power small electret condenser microphones. The adaptor cable will therefore need to have blocking capacitors in it to prevent this DC power getting to the headphones. Do this (or switch off the plug-in power) and you can then use your headphones as microphones (how good they will actually be is another thing as they were designed to be headphones and not microphones and the impedance may not be the best match - but it should work.)
post-5406448
Post #19 of 28
John Willett
Yes the *do* output a signal - they are likely to output 5V (or so) of DC voltage to power electret condenser mics. See my post above.
(deliberately left as two posts as you don't want a DC voltage being stuffed into the headphones)
post-5406454
Post #20 of 28
eruditass
Previously known as DoomzDayz
Maryland
Maryland
used ksc75's for ventrillo when i was CSing up in Hoboken..
whoa whoa whoa who did that? dumbest thing ever. amps are designed with input/output caps just to get around DC biasing which can damage drivers by causing them to not fall back and stay in a resting position
post-5406516
Post #21 of 28
apatN
Pretty cool. I did not know you could use headphones as a mic.
post-5407790
Post #22 of 28
boomy3555
Since it's all about moving air, it's just hard to get the driver to move enough to create a signal from just the sound of your voice
post-6497855
Post #24 of 28
Adamora
Random zip file is random .-.?
post-6499287
Post #25 of 28
PianistOne111
Well, seeing as I can't attach audio files on these discussion boards, I put it in a .zip archive and attached that.
post-6499320
Post #26 of 28
logwed
I used my Portapros as a mic one night. It was an interesting experience for those on the other end, but once I took the pads off and arranged it in a way so that I could speak into it, they worked fine.
post-6499716
Post #27 of 28
Sambones
Actually, one of the few things that the AKG K26/27i is good for is a mic. In fact, best mic I've ever used.
post-6499737
Post #28 of 28
Bilavideo
Caution: Incomplete trades.
You can use any speaker as a mic. Whether that speaker is ideal for the job is another story. I can remember doing this when I was in junior high, and then getting ridiculed by a guy who told me I couldn't do it - so I showed up with my cassette recorder and this 10 inch driver to show him he was full of crap. It was a minor victory but one I insisted on having. An ego is a terrible thing to waste.
