Hmmm. You're in Canada right - are you familiar with a store called XSCargo? There was discussion in the thread for the Somic MH463 that there is a rebrand of this headphone on clearance for $29.99, under the Lethal Audio brand. For $30, that's about the best band for buck you'll get! Pretty crazy price. Only Canadians seem to be able to take advantage of it though. $60 for my pair was a good deal at the time. They're considered budget beaters, like the M50. I personally think they wipe the floor with them - the just do everything better (great audio quality, huge 50mm drivers, open-back for wider soundstage). Just be aware of the various 'quirks' you'll encounter with these cans
. Take a look at some reviews and read this thread:
http://www.head-fi.org/t/637699/50mm-driver-open-air-full-size-cans-pop-out-of-nowhere-sound-amazing
On page 33 is discussion on the Canadian rebrands.
If I were you and they were available, I'd get them in a heartbeat. For that kind of money you can't go wrong.
Edit: Plus, seeing as you can buy in person, you'll presumably also be able to return them if something is wrong or you don't like. You'll get to test them, effectively, instead of blind buying.
