TeLight
- Jan 13, 2009
Hey there guys, I should probably begin buy saying that I currently have HD555s and XF-I "something" sound card (its either platinum or titanium, extremely hard to tell). I was thinking on upgrading for next year.
Originally i was leaning towards the HD600, but now somewhat the HD650 since it can be had for only $60 more on Amazon. For the sound card i have it narrowed down to the HT Claro, with the Hi-Fi amplifier (1.5W into 32ohms), which should be more then enough to drive the any set of cans.
Do PCI sound cards have better sound quality then USB ones (dreaded PCM2707)? Without the USB chip, is linearity better achieved? If I'm completely wrong then, can someone recommend a USB amp/dac for $200.
The kind of music I mix is mostly electronic, although i love to use acoustic sounds such as guitars and pianos.
I should also note that completely cannot stand bright sounds, i dont like boomy bass as well, but my music have been know to sound kinda dull to some people due to my subjective musical bias(less treble), this is why I'm leaning more towards the HD650 as I have heard that it is not as bright as the HD600. A less brighter set cans means ill mix more treble, and hopefully sound good to other people and myself
Although neutrality is very important to me, but with just a tad less treble. (Really only a little bit)
Anyway, I want to thank all those that respond, and make suggestions.
P.S. Don't hurt my wallet too much
