Darkr
- Nov 22, 2014
Hey community,
Name's Darkr... And I need help with a choice. Which one should I get??? Here are some links=
http://en-ie.sennheiser.com/pc-gaming-headset-g4me-zero
vs
http://en-ie.sennheiser.com/high-end...eo-hifi-hd-598
Also, if you know any better beyerdynamic ones better than the above ones, please tell me too. My budget id about 150 - 250 euro, the hd 598 are on 200 euro because of a amazon discount. I will mainly use this for gaming, maybe sometimes music.
PS Also mention what you think is best out of the two, even if you have a other suggestion. Helps alot =)
Thanks
Darkr
vs
Thanks
Darkr
