Headphone cables interchangeable between Beyerdynamic and AKG?
Jun 22, 2023 at 2:31 AM Thread Starter Post #1 of 5
FritzS
Austria, Europe
Are headphone cables interchangeable between Beyerdynamic (DT series) and AKG (Kxx series)?
Specifically - can connection cables from the K702, K712 also be used for the DT1990 Pro?
Sep 27, 2023 at 9:09 AM Post #4 of 5
@FritzS Yes, you can use the same cable for both AKG and Beyerdynamic, as they use mini XLR connector.
Just the fact they use a mini XLR might not be enough. Are you sure the pinout is the same?
