RollsDownWindowsManually
- Oct 26, 2001
Why is there no standard among headhpne amp producers for power ratings?
For instance, with most home and automotive amplifiers, you will see power ratings at 4 or 8 ohms, 20hz-20khz +/- 3 db, and less than 1% Total harmonic distortion across the spectrum. Most headphone amp producers (headroom, ray samuels, electric-avenues, and even xin) don't have any power output specification. To me, the sound quality of an amp should be a given if the THD is low and the frequency response is broad. The only power output spec I could find was for the heed canamp.
Heed CanAmp: 300 mw @ 100 ohms, <.05% THD, 10hz-50khz +/- .5 db
Since power output is in my opinion, the most important rating for an amplifier, does anyone have power output rating for some of the more popular portable amps @ 100 ohms, for instance say:
Xin Supermicro
Hedaroom Total Airhead
Ray Samuels Hornet
PA2v2
Thanks!
Xin Supermicro
Ray Samuels Hornet
PA2v2
Thanks!
