Sonorous Bleb
Ah... So my untrained ears may not pick up that something is amiss without comparing with another DAC? That's a pain. I'll see how it sounds, though.
Are the reviews you've read of the Asgard 3 DAC fairly old? I've been reading that the DAC was changed from the AK4490 after a fire burned down an AKM factory. They now use an ES9028 in the Asgard 3, which seems to be the same as in the Modius. I don't know whether there's more to it, but maybe that means that the DAC issues in the Asgard 3 have been solved.
Yes, I though that direct to PC would probably be my best bet. Thought I'd better check, though.
