Do I really need a 1000V voltmeter for this or 600V is fine? I guess 1000V is to be on the safe side in case of inserting the pron in the wrong hole or for tubes that are not behaving right?
Attorney: I've tried around 5 different tube types, and all of them gave the same readings within a small number of volts (balance/offset), so no you don't need to go above 600v in normal circumstances. The most likely reason for ever needing 1000v, is if you keep twirling the wrong adjustment pot by accident and ending up off the scale. Even then, you have to do an awful lot of wrong twirling to get to 1000v. Anyway, if you've yet to buy a voltmeter, then even cheapo ones can do 1000v, but not all of them, so need to check the spec. If you've already got a 600v meter, I'm sure that will be fine 99.9% of the time.
Also, someone told me it takes 3h for the amp to really settle. How are you guys using your BHSE? I was wondering if buying cheap tubes for keeping the amp warm when not used makes sense? That means I would be adjusting offsets everyday (when rotating the "keep it warm" tubes and the "listen to music" tubes) and going through multiple on/off cycles (at least 3 on/off cycles) which can't be the best for the amp I imagine.
Attorney: That doesn't sound like a good idea. Far too much faffing around. Plus it takes 3-4 hours for the tubes to fully settle down (i.e. when balance/offset stop changing), so if you swapped tubes, you'd have to wait another 3-4 hours for optimum results, which kinda defeats the object. I know some say 1 hour is enough, and it is in general, but if you want optimum, then 4 hours is better.
I guess those NOS mullard and stuff can last 8-10000 hours given they're not particularly strained by the BHSE. But still, that's barely a year and half of 24/24 power on. Considering how bloody expensive EL34 have gotten in the past 5 years, I can't imagine just leaving the amp on all the time is a good recommendation, even assuming one listens to it every day.
Attorney: I don't recall anyone ever recommending leaving their BHSE (or any tube amp) on 24/7, and for good reason. Just put in the NOS tubes, permanently and switch on the BHSE the evenings when you want to listen, then switch it off at the end of the evening.
Headamp Blue Hawaii Special Edition
- Thread starter audiosceptic
wink
His amps are made out of recycled beer cans
and his source from tomatos.
- Apr 13, 2009
^ Sound advice......
- Jul 9, 2008
Order one now - you know you want to, spots fill up fast. Besides, that will be 3 of use that I know of that will have the BHSE \ TotalDac D1-Dual combo.
magical combo!
congratulations Arnaud!
preproman
- Mar 16, 2011
Ali-Pacha
- Mar 19, 2013
You really do want me to buy a totaldac ? You bunch of evil tempters
Ali
Ali
preproman
- Mar 16, 2011
Ali
Lets go Ali - make it happen..
NoPants
- Aug 14, 2006
Ali
For the totaldac price there are a lot of other interesting options, maybe used DCS
goobicii
- Feb 21, 2013
If I was to spend more than 200 dollars theres no way in hell I would buy a stupid sigma delta that doesnt even play real music but ****ty unaccurate immitation of original signal,I would even rather have a mediocore 30 year old TDA1541 dac that even priciest of S/D dacs
R2R NOS ftw!!!
NoPants
- Aug 14, 2006
I don't even know what to make of that statement
Anyways, the DCS ring DACs are interesting if you look some of the ideas and performance gains. I think there's some other DACs which try approahces with similar, like the metrum pavane.
But there's always the measurement graphs on the totaldac site which show the utterly amazing -100 dbfs performance, clearly it's the best choice
Congratulations on the blue hawaii that people are receiving, I really enjoyed the short time I spent with mine. I might end up finishing my T2 before I get around to finishing the 2 BH's I have on the bench though. More for the marketplace I guess
- Nov 26, 2002
Drama queen - Part II...
So, you would think I spent the last week making myself deaf by listening to the newly arrived BHSE.
That was the plan except that my BHSE suddenly stopped working after a couple of days for no reason (well there's always a reason though).
What?! What is this?! I can hear a very faint sound when I push the volume to 11AM, something went awfully wrong there.
As usual, I fire off an email to Justin and I get a response within 8 minutes [I don't recall ranting too much about Justin's lack of responses to email sollicitations but if I did, I take it all back: the man just sorts through the non-sense and be assured that he's on it when the case justifies it].
And there starts a journey of diagnosing what is wrong with my amp, thousands of miles apart. Very soon, Justin finds out the phones are not getting biais voltage they need to operate, hence the whispering operation mode.
Since I was using PSVANE EL34PH, with their dreadful reputation, I soon wondered if this was because of the tubes. Popped in some Mullard XF2s OO getter, same result...
Testing the voltage across the stators when playing pure tone, everything was absolutely fine except the bias line which is quite isolated from the rest. We started to measure the cord, voltages at the PSU end, voltages at the umbilical cord end on the amp side, everything was fine.
Conclusion: problem on the bias line, inside the amp, I need to take the top cover off. Gosh, I don't want to scratch these screws, the thing is spotless! No choice. With me, that was already a challenge in itself as I could not resolve myself to force the screw driver into the first vice (the anodizing / painting make it a very tight fit). A couple of wrong screwdrivers ordered later and clarification, I finally managed take the 12screws off [for reference, size is 5/64" or .0781, close to 2mm metric].
Here's a topview, we can't see much as most components are soldered on the other side but we can already tell the thing looks almost absolutely symmetric and is all very neat:
Looking at this, all seem fine so I start measuring voltages and resistance across various pins. With a certified EE moron like myself, that took a bit of courage to get to do this, especially unit on:
Unfortunately, no different results from before. By that stage, I was a bit desperate, already looking into shipping fees back to / from Headamp. Justin did not give up there and proposed me to perform additional diagnosis, taking the bottom panel off next...
I wake up at 5AM to get to do this before the kids wake up / work, 24 screws later this is what I see, this thing is just as clean / awesome looking from the inside as it is from the inside, admire Justin's work here:
The bias line runs on the very right side of the board. From the back, through a couple of capacitors / resistors to the headphone jacks (with 5.1M ballast resistors). Soon enough just asks me for additional close up pics of resistor R28 (between the 2 rectangular red color capacitors). This is what I get:
We can see a very tiny piece is junk on the left solder joint, it's actually barely visible by eyesight, I used the iphone camera for this.
This turned out to be a very very tiny piece of metal that was shorting to ground. The thing is maybe 0.25mm this and 1mm long that tiny! No idea how this got there, how in hell it started to become conducted after several hours of use. But the matter of fact is that once I took it off with those hair removal thingies, the amp started to measure just fine. Put a little bit of nail polish there just in case, reassembled the panels back and we were back in business. I have been using it a bit since, it's been rock stable.
Moral of the story for me: Justin really know what he's doing, he's extremely serious and responsive when it matters and makes f..ng beautiful amps both on the inside and outside.
Second moral of the story: these high voltage amps are very serious business. 600V floating here and there means you don't need much at all to create shorts. I would love to build myself a T2 someday but I realise this is wishful thinking when I see the above. Maybe start with a bottlehead crack for my HD600 first .
The diagnostic process was quite an enriching experience in itself and, while scary at first, it saved a good chunk of money and hassle for me and Justin [ you guys waiting for your BHSE can thank me ]. Justin was telling me there's a good chance this piece of metal would have fallen off during shipping back to him, he would have found nothing wrong with the amp, he and I would have been pissed at wasting such time and money... Oh am I glad about this current happy ending.
Ok, enough drama, hope some of you enjoyed the read
cheers,
arnaud
cheers,
arnaud
Here's to hoping I don't have to do any repairs myself, although the engineer in me would probably get a kick out of it
David1961
- Dec 29, 2010
@ Arnaud,
It's good to know you got the problem sorted.
Thank you for those lovely photo's arnaud. The care and attention that goes into every amp is amazing a thing of beauty in my opinion. As beautiful the BHSE is on the outside (and i have yet to see photo that truly captures this) in a way i actually find the innards even more stunning. Components are all placed with such precision and all joints soldered properly. The attention to detail is STAGGERING! There are probably more than a few companies out there that could only dream of producing something as awesome as this.
Justin Wilson REALLY knows his stuff and i myself look forward to receiving my BHSE one day.
Congratulations arnaud i am sure she will give you many years of listening pleasure.
preproman
- Mar 16, 2011
That's a pretty good amp you have there driving the Woo Wee..
Total: 14 (members: 0, guests: 14)
