Thanks for this short and informative summary! In fact, I own the two headphones, the AKG K701 and the Sony 7506. From my own experience, I can confirm the above comparison.Hey Head-Fi!
I've been seeing this myth floating around a lot and I feel like I'm constantly correcting posts about how hard it is to drive a headphone on this. The worst part is that new users read this generalization and then start telling other people that impedance is how hard it is to drive a headphone, and then more new users read those posts...
Like most myths, this one is rooted in some truth. Generally speaking, high impedance headphones will be more difficult to drive, especially those with 300 to 600 ohm impedance. This is not an absolute!
The second part of the equation is the sensitivity rating of the headphones. This tells you how many dB the headphone outputs at either 1 mW of power or 1V. This is equally important!
For a good example, compare the Sony MDR-V6 and the AKG K701. The Sony MDR-V6 has 63 ohm impedance, whereas the AKG K701 has 62 ohm impedance. By the myth, the K701 should be easier to drive. Wrong! The Sony MDR-V6 has a sensitivity rating of 106dB/mW and the AKG K701 has a sensitivity rating of ~92 dB/mW. In reality, a portable device may take the MDR-V6 to 110dB, but an amp may need 5 times as much voltage to make the AKG K701 reach the same loudness.
From a purely technical perspective, it is harder to drive a low impedance source -- it's just that low impedance headphones nowadays typically are paired with high sensitivity ratings because they are designed to be played from portable devices. If a headphone has a low impedance and a high sensitivity rating, it will be very easy to drive. If a headphone has a high impedance rating and a high sensitivity rating, it should be easy to drive. If a headphone has a high impedance and a low sensitivity rating, it will be hard to drive. If a headphone has a low sensitivity rating and a low impedance rating, it will be very hard to drive.
[Head-Fi PSA] The impedance of a headphone is not how hard it is to drive.
- Thread starter SanjiWatsuki
