High_Q
- Mar 20, 2010
I have this amp:
http://www.head-fi.org/forum/thread/410886/elekit-tu-882-vacuum-tube-5670w-x-2-headphone-amp
And I am getting distortion at low impedance setting(4-32ohm) for my HD800. Can anyone explain how output impedance reacts with headphones of difference impedance? HD800 is 300ohm. Why would it distort at low impedance setting, my HD650 doesn't, I though lowest output impedance setting is desireable for damping?
- Vacuum tube / 5670W×2
- Rated output / 200mW(RL=6Ω or 32Ω or 600Ω)
- Output impedance / LOW 4~20Ω、MID 20~100Ω、HIGH 100~1kΩ
- Rate input / 400mV
- Input resistance / 50kΩ
- Frequency response / 20Hz~50kHz
- S/N 102dB(IEC WEIGHTING)
- Voltage / AC120V 50/60Hz
- Dimension / W130×H120×D250mm
- Power consumption / 10W
