milosingh
Now known as Techboy
- Dec 31, 2013
Asus DX can't drive HD 598. Sell it. Use the proceeds to buy a DGX. You won't need to put in any money.
I just changed my drivers to the new uni xonar, and now my conf. is set like this:
http://imageshack.com/a/img924/9431/8xwS6y.png
its correct?
i dont have plans to buy another card right now... i will stay with xonar dx only and them, someday maybe i buy one better soundcard, with internal amp.
E6 is rubbish. Asus DGX is your best bet. Just USD 25.
If you have a modern smartphone you should be fine as well.
but, if i use my xonar dx + e6, will be better sound quality them dgx?
i dont want to downgrade my soundcard too.
but, if i use my Xonar DX + E6, will be better sound quality them DGX?
i don't want to downgrade my sound card too.
I really appreciate all the comments here, and wanna thx all the help.
I'm get a little bit confused, so here is my final asks.
1) will i notice any difference in the surround using external amp or other sound card with internal amp (difference in FPS games for example) ????
2) probably will not be easy to sell my Xonar DX, so my options are:
buy FiiO E6 er FiiO E11 (if e11 is really way better) + my Xonar DX
or
try to sell my Xonar DX and buy one Sound Blaster Z (only if it really improve my surrounding in fps games)
Remember, i don't have lots of money to spent now, so, i need to think in terms of cost benefit.
