cel4145
Well I'm not a basshead, i just gave few examples of what electro/trance music I listen toFrom Beyer I'm leaning more towards DT880 250Ohm Pro, I've read that they have better mids and highs then 990 but less bass (still more or close to HD598) so they would probably fit me better. Xonar DG is not enough to drive them right?
That's a difficult question to answer. There are people that find the 250 ohm Beyers work fine with the DG. If you are planning on running them very loud, you might want something with more power. That's the hard part because it's difficult to communicate how loud you like to listen for people to tell you.
Have you considered the Soundblaster Z? It's rated for higher impedance and generally considered a better sound card.
