BingCrosby1903
- Oct 2, 2010
Hello guys,
I'm about to buy Senn HD 800s with either the Lehmann Rhinelander or Black Cube Linear. I am a HD 650 owner.
While I know there are a lot of subjective differences in sound quality between amps (I have an X can v 3 which I don't like),
I'm wondering how one can justify the extra price of the high end amps, when for instance, a mobile phone headphone jack can have better channel separation (and very obviously inadequate power to drive these cans) than the BCL, or an Asus STX has better SNR?
So what I'm asking is if there is a technical reason why two amplifiers, driving the same headphones at the same volume and not clipping have a different sound, and in particular, why a more expensive amplifier with some worse specs sounds better than a cheap headphone jack with some better specs? Because typical hi-fi specs seem to indicate that some cheaper amps would produce a more "electrically perfect" wave form to drive the headphones with, even though the high end model was fully discrete, has a toroidal power supply, better quality parts etc. Perhaps very different standards for measuring specifications? Different output impedance characteristics into a given load?
In the case of the HD 800s and BCL, I believe the HD 800s were designed with this amp, so their frequency responses will be exactly matched.
While my heart says get the more expensive amp, the technical side of me says "I need to know a reason why it is better?". I'm sure a lot of you guys have had this thought too.
Thanks for your input and explanations and NO, I'm not going to be driving the HD 800s with a mobile phone or an STX!!!
Kind regards and seasons greetings,
Peter.
Peter.
