Roy2001
- Oct 25, 2002
Thanks chkelly, I also ordered the HD590 from J&R. There is a free Sennheiser watch which is OEMed by Seiko, not the crappy no name watch you can find for $20. I believe it worth $50. (PM me if you want to buy it
The phone itself is very light, much lighter than I expected. The original cable is thin, but I don't care as I will buy the parts to make cable by myself.
I connect it to my CD player. The CD player is a 5 years old Philips and sound quality is not bad. Well, the sound is OK, but not very impressive. The bass is low and pretty tight. Actually bass is better than many good speakers. But midrange is less transparenct than I would expected. The female voice (the famous blue raincoat) is not warm at all. I thought it might be the fault of the CD palyer. So I connect it to Denon 4800, no much difference.
Then I connect it to my Audigy. It sounds a little better now which I believe cause I have listened for a while. I played Counter-Strike, there is more datails which I never heard before with my crappy Labtec phone. But the bad news is I don't like it. Some guys said 590 is too bright, but I cannot prove it. It might be too early to judge.
I will report the sound after burn in and new cable is ready. I am not an audiphile, but my ears is used to my NHT 3.3 which has the best bass I ever heard.
