Yellowjacket
- Apr 19, 2002
The direct replacement cable for my HD 580 are $34 from Sennheiser, whereas the compatible HD 650 cable is only $19. Trouble is, I primarily use my headphones with a 1/8" source and the 650 cable terminates 1/4". Now, using a 1/4" -> 1/8" adapter isn't a huge ordeal since I don't use them with portable sources, and the cable itself is a little thicker which will help with durability. Does anyone have experience with this kind of adapter setup?
