rickcr42
Are YOU talkin' to me?
- Jun 21, 2001
While pine is not usually considered the best choice , I say go for it man,you have nothing to lose and everything to gain.I would never use solid panels in an enclosure with a dimension larger than the largest available lumberyard panel (usually 12 " ) unless I had a 'joiner".
That is a tool that shave the sides of stoch wood to obtain a very precise surface which allows joining pieces of lumber side by side to get the desired width.This multistrip glued panel is then run through a planer to smooth the surface.That is how table tops are made.
But up to the foot wide point,why not
And by rustic finish you mean ?
When I finish wood I like to use the MinWax products.The wood stain is very easy to use,just 'rag" it on,count to 10,wipe the excess with a clean rag.After drying you can then put on a coat of polyurethane with a good china bristle (natural horsetail bristle) brush.Use longish strokes,not choppy or stop and go.I use the satin finish mostly but some like the gloss.If the temps are over 80 and the humidity is low you can sand the poly with #120 grit sandpaper or #000 steel wool,dust off the finish and then wipe with paint thinner to get the rest.
Add another coat of poly
DONE DUDE
Of coarse you can go farther with the coats and steel wool with finer grades between coats,pumice stone final coat,but really is overkill in a speaker enclosure
Now piano black lacquer is a different story ! Don;t ask man,you don't want to know
DONE DUDE
