Garbz
- May 19, 2004
Ok I designed it a while ago. I got around to etching the boards today, and I took a look at the ground trace. Something about the design does not smell good, just a hunch really.
The basic idea originally was to make a TL431 based shunt supply. Then the idea was made to split it so I get +/- from 2 separate xformers, and make a ground at the regulator output kind of like the pre-regulator on the gilmore Dynahi PSU.
Anyway can someone here confirm my hunch that this may not work? Specifically I do not like how the LM317 (configured as CSS) is connected to GND on the -ve side. I get the feeling it will let the magic smoke out.
http://www.garbz.com/sch.pdf
