zareliman
- Mar 29, 2012
Hi headfiers
I recently stated to get a little worried because specs on some headphones not always put rated power and even less frequently put max power or handling power. Even when they do this specs sometimes do not seem to make sense. a 102 dB/mW with 2000 mW of handling power is not something that I would just take word for without seeing some extra data like testing conditions, frequencies, etc... And even then, I've never seen a curve of life-expectancy / power or something like that because to me it makes sense that the same headphone running at 20 mW will last longer that the same one running at 500 mW. It is RARE to see the number of working hours a headphone driver is expected to last on your regular headphone specs. Not all drivers are made equal, there's titanium coatings, kevlar, paper, lots of different plastics, sizes, efficiencies, mass, etc. So they probably don't last the same, then, what is like the minimum standard for them ? 500,000 hours or something ?
And then there's planars, I don't even know if those can be blown or what really happens if you overpower them. Also I don't know about their longevity, I imagine they put less strain on materials because there's no deformation of a shape, but I don't really have a clue.
Electrostats are probably not an issue because they come paired with their own amp so I assume the manufacturer makes sure you can't kill your headphone with the supplied amp. Still they work at brutal voltages, maybe they're dangerous past some point ?
So I just wanted to ask about some real life experiences, Have you blown a can?, How did it happen ?, How many years of use before death ?, Driver type, size, rated power, etc ?
