obobskivich
exactly thank you would you use the whole stack? If i can i think i will i got an amp and dac the schiit stack
Yeah I would hook it all up - you can always plug into the card's headphone amp directly as well (as long as the card is in "Headphone" mode that jack will be active ++ the digital output as long as "Play mix to digital output" is enabled; yes you can have both at once). This also leaves the L/R analog output available for hooking up to some other component (e.g. speakers) as needed.
