Has anyone tried this? Insert their low-end DAC (like Schitt Modi 2 Uber or Bifrost, Bel Canto DAC-1, etc.) between their cable box or Blu-Ray player, and Sound Bar or Sound Base? Without a dedicated DAC, one is relying on either the $5 DAC in their Blu-Ray player or the $4 DAC in their sound bar. It seems inserting ones inexpensive DAC (or leftover DAC, from before they upgraded their headphone setup with a new $800 - $1500 unit) should provide several orders of magnitude of improvement in their television listening experience.
Sorry if this is a little off topic, but by the same token people here are likely to (at the beginning of their journey at least) have an inexpensive DAC that would take about three minutes to insert between their cable box, Blu-Ray player, or receiver, and their low to medium cost sound bar setup (or, if you are like me, ZVOX sound base). I start here, because I expect most of the people here would not be able to stomach listening through their TV speakers while watching TV.
I know a Surround System is better, but I've had three low-end soundbars (well, two low-end and my current pretty-good sound base) using analog interconnects and power cords that perhaps cost more than the units themselves - and for sure the accessories cost more than the speaker if you include the PS Audio Duet power conditioner I use - that had a degree of realism and soundstage; they were not terrible for listening to music, especially if you were listening in the other room.
It seems to me even the (for many of us, really low-cost) $149 Schiit Modi2 Uber should be a leap forward of several magnitudes for Television watching/listening. Comments or experiences?
Back Story, if anyone cares:
a) I am upgrading to DirecTVs latest DVR, the HR-54, and it doesn't have RCA analog outputs, just HDMI, digital coax, and digital optical outputs. It does have a 10-pin A/V out plug which can be used with their $6 10-pin dongle (with two RCA audio connectors on the other end and three component video connectors - of course this would be unacceptable
b) Therefore, I have to find a way to get an analog signal to my ZVOX sound base, which I love dearly (for non-surround applications) but the DAC in it is fair to poor, as one would expect. (Yes, I know I can hook up a RCA interconnect to my television and run it to my sound base, but then I'm relying on the same $5 DAC in my television.)
c) So, using an inexpensive DAC seems like one solution, and it seems a cheap one (by Head-Fi standards) should yield a 100 fold improvement over the one in one's cable box, blu-ray player, or sound bar. Anyone try this yet?
