Towert7
- Aug 31, 2005
The Havana is nothing short of phenomenal.
The amp you pick should be chosen wisely to maximize the synergy in your setup, which will depend on what headphones you end up getting.
The GS-1 is seriously wire with amplification. It gets out of the way and just lets you listen to your source. This is why I picked the GS-1. The WA6se will alter the sound a little, and depending on your headphones and your preferences this may be a good thing or a bad thing.
My Havana > GS-1 > HD800 is one of the most detailed setups I have ever heard, easily beating out a Cambridge Audio 840C > HEV90 > HE90 setup.
Because the HD800 is so detailed, you will be able to realize the differences between the two amps.
Which ever you get, your setup will sound wonderful. Subtle differences will be made by your choice of GS-1 or WA6se, but when you get to this level sound quality, that subtle difference can make a good setup a great setup (especially with the picky HD800).
What I am trying to say is: Choose wisely! ^_^
Originally Posted by DarKu /img/forum/go_quote.gif Thanks guys I think i will order an WA6SE wondering if in the future i could mod it myself with premium parts upgrade... |
