I deliberately keep my objective testing and subjective thoughts separate, as I don't want people to think that I'm Amir 2.0 or something where higher number always is better.What I found interesting is on the website that you credit for the pic of the U18 internals, there's a user reviewer who states he likes the U18 more than some of the other units you tested and he has owned with better numbers. I think reviews/comparisons like yours should be a combination of objective numbers testing and subjective listening comparisons. I think too many people base product like/dislike decisions based on numbers alone. Personally I think the U18 would be hard to beat in terms sound quality per cost. Thanks again for the time spent on this. 2 thumbs up!
I feel measurements are a way to explain trends or subjective findings, not a way to give a definitive better/worse ranking.
I'll sometimes put a bit of subjective description into objective testing if I think something is explicitly relevant to or could explain a subjective characteristic, but other than that I try to keep it as separate as I can.
Subjective reviews are posted either in video form on https://youtube.com/goldensound or in a separate website post.
I did post in a couple places and in discord etc about my subjective findings with the U18. It seemed to make things a little bit more crystalline/incisive but also actually hurt precision of imaging a bit.
I can totally see why people like it, but personally I felt other DDCs like a Singxer SU6 did a better job without the drawbacks.
In regards to objective 'rankings', generally I feel there are simply too many factors to consider and there is no single number that can determine the overall quality of a product. If that were the case Tube amps wouldn't exist.
This is more the case with DACs/Amps where there are countless factors to consider.
For example, the Gustard X18 outperforms the Benchmark DAC3B in THD+N/SINAD pretty comfortably. But then it falls on its face in the presence of intersample overs and that causes massive distortion, whereas the DAC3B handles them perfectly. So who is to say whether that extra few dB of SINAD is worth that drawback, or whether the differences in say Jitter performance, IMD, oversampling filters etc are more/less/equally important?
With DDCs though it's (a bit) less the case. They aren't analog devices, and so there are only really three factors to consider:
- Data integrity (so far I've not encountered a DDC that wasn't bitperfect other than the MScaler which ofc changes the data as it is an upsampling device)
- Noise
- Jitter
Level vs spectrum of both noise and jitter is a different debate and two DDCs with similar RMS jitter but very different structures can still sound different, but still, for the most part a DDC will either have overall higher or lower jitter than another.
(Also, there's of course always the issue of expectation bias. If a DDC is a big, expensive behemoth like the DI20HE, people will EXPECT and be more likely to hear a greater improvement compared to a smaller, less expensive but equally or better performing one like an SU6.
Realistically the differences with DDCs are usually very minimal, more minimal than DACs, and so expectation bias and placebo are bigger concerns.)
