ProLoL
- Jan 13, 2017
I had both the SU2 and U16, I do prefer the sound of the U16 but the SU2 is not bad.
Not really. The 1.61NFB firmware is the only firmware I find working flawlessly and sounding good. I am using Linux (ALSA) players. I have no experience with Windows.Can someone tell me where the difference between firmware 1.61 and 1.61NFB is?
Ok, then I'll play the 1.61NFB on it now.Not really. The 1.61NFB firmware is the only firmware I find working flawlessly and sounding good. I am using Linux (ALSA) players. I have no experience with Windows.
/Jan
Thank you for this info, then I don't need to test the other versions.I get the info from Gustard directly that the NFB Version is specially optimized for MAC and Linux Systems.
Gustard told me 2 weeks ago that they don't plan to release further updates because they think 1.61 and 1.61 NFB is "perfect".
Thanks Jan,
No.Sorry if the question has already been asked, but can the display be dimmed or switched off somehow?
Flash on 1.61NFB. Download from here: https://onedrive.live.com/?id=636DC4E8060D66A1!380&cid=636DC4E8060D66A1Unfortunately, the U16 doesn't work for me.
It runs for an hour or less, then there are dropouts - I have tested firmware so far:
1.40
1.40 PSA
1.58
1.61
1.77
The source is a Raspberry Pi4, with Volumio.
DAC is the Gustard X16.
If I connect the RPi4 directly to the X16, everything is fine.
Cable is an HDMI from AQ.
Anyone have an idea?
Did you buy it new? Return it and get Singxer su-2.Unfortunately, the U16 doesn't work for me.
1.40
1.40 PSA
1.58
1.61
1.77
Thank you!Did you buy it new? Return it and get Singxer su-2.
I owned U16 for a year and had terrible experience with it. It doesn’t have a single firmware that is bug free. The designer said U16’s Linux support is poor, but the windows support not well neither. Look for my history post in this thread for detail.
Gustard has abandoned the ES8620 USB solution in all their later products and gone back using XMOS. That proves everything.
Did it before, just forgot it in the post above.Flash on 1.61NFB.
