Just buy the PSU you mentioned
http://item.taobao.com/item.htm?spm=5706.1529727.a31f1.2.6aLAkp&id=39418148280&scm=1007.11502.5699.0&pvid=8036e3ab-d8cd-4d83-bebf-d125af2e6750&utm_campaign=website&utm_source=sendgrid.com&utm_medium=email
AND
Buy a JZ-1 (you need to know voltage of your Crystal Oscillator)
http://item.taobao.com/item.htm?spm=2013.1.20141002.6.UOBL1V&scm=1007.10009.3949.i24423568640&id=18140229202&pvid=38a111dd-6370-4267-a52a-24585aae2518
Kingwa says that JZ-1 performs VERY good EVEN when powered with simple psu.
Or, just use the one i noted before
http://www.diyinhk.com/shop/audio-kits/73-08uv-ultralow-noise-dac-power-supply-regulator-33v5v-1ax2.html
This one has 0,8uV noise only!!! AND it's for 2 crystals, can set 3.3V or 5V, based on LT3042
You need 2 psu's to power this very good regulator
I probably wi try this one in MX-U8 with 2x simple psu's which i have to build myself (within MX-U8 enclosure) to feed the NDK Crystals
