natra084
- Oct 21, 2014
Check your audio settings:
http://www.macobserver.com/tmo/article/audio-midi-setup-your-macs-secret-sound-manager
does the u12 up sample
If you are using a PC and Foobar you can try the SSRC (super secret rabbit code) or SoX upsamplers. I have both and love the SoX. Both are free.does the u12 up sample
I am new here and ordered U12 yesterday from Shenzhenaudio.com.
Does anybody know whether there is a decoding function of DoP?
I mean, getting DSD native signal from I2S for DoP input.
My DAC has I2S/DSD input (RJ45) which accpets PCM and DSD native, but not DoP.
For DoP, I must use the USB input of the DAC. Inside there is a DoP USB-I2S/DSD board like Combo384.
DoP is necessary for DSD playback with JPLAY. My DAC is similar to LKS MH-D002 from a small Japanese manufacturer.
So, my current chain. Computer > Wyrd > Gungnir > Lyr 2 > HE-500.
If I unplug the USB cable from my computer, static is gone.
If I unplug the USB cable from the Gungnir, (So, no computer, no Wyrd) the static is gone.
If I leave the Gungnir plugged into the Computer or Wyrd>Computer, but unplug the RCA's from the Gungnir that go into my Lyr 2, the static is gone.
I suppose, this means either the USB connection is causing the static somehow, or the Gungnir itself (or it's USB interface) is causing the static.
I could take all this stuff home and try using my Oppo or my UMC-200 to see what changes I get mixing things around.
If you are getting static one of your components is defective. Could even be something as simple as a cable but it is surely a defective component. You did not say if you get this static equally through both channels? That would help sort this out. Any component from the computer through the headphones could be the problem but if it is in both channels it is not likely the headphones. I would not suggest spending money on another component until you track down the source of the problem.
