Hi everyone, I've just finished building my ultra-low noise power supply based on the 0.8uV DIYinHK kit and I'd like to share what I've found about this kit.
First, some photos of the build:
Since I need 1.6A supply for my NAD D1050 dac, I paralleled the two individual 5V outputs with some changes to the original circuit. Theoretically, paralleling the regulators will reduce the noise even further, to 0.57uV in my case. However, there is no way I can measure it with my humble multimeter. What I do know is that right now, it's working perfectly with my DAC. Actual output voltage: 5.06V. Current consumption is very steady at 1.4A, exactly 0.7A measured from each output, what a perfect balance of load! I am amazed at the performance of these nice LT3042 regulators.
After I put my new power supply into service, my wife immediately noticed improvement in the sound. She said that the sound was SWEETER, to which I fully agreed. Previously I always start to feel a little fatigue after listening to my system for more than one hour, now that fatigue is all gone.
I am now very happy with the combination of my power supply, my dac and my U12, although I did encounter quite a few issues while building the power supply:
1) Although DIYinHK claims that this kit is capable of supplying 1A x 2, I believe that the original design is only good for a maximum of 500mA x 2. The Murata hybrid EMI filters supplied in the kit are rated at 500mA only. In my initial tests, they got VERY hot at 500mA. Once the current went above 500mA, the filters got saturated and there were a huge voltage drop once the chokes were saturated. As a result, the output voltage plummeted to 3.7v from 5v upon saturation. This alone won't be too much of a problem if you only need 3.3V. The board can still output a steady 3.3v if you set its voltage jumper to 3.3v. But since I need 5V, the voltage drop was totally unacceptable to me. Eventually, I had to bypass the two nice-looking but useless filters to get a steady 5V output;
2) The default heatsinks that come with the DIYinHK are too small for current output above 500mA. The transistors got burning hot when more current was drawn. I was so alarmed at this that I checked again on the DIYinHK website to see what could be wrong. This time, I noticed DIYinHK's warning to use larger heatsinks or a fan for cooling if more than 500 mA current is needed. To make matters worse, the PCB was specifically designed to allow only a small heatsink to be installed. There are capacitors right beside the transistors, leaving no room for larger heatsinks. Luckily, I've already replaced most of the WIMA film capacitors with tiny 22 uf surface-mounted Murata ceramic capacitors, so that I have space to mount larger heatsinks above my capacitors. This tames the heat nicely, although the board doesn't look as nice and neat as before;
3) Regarding the choice of transformers, I originally ordered a R-core but decided to try an EI core first because of their alleged superiority in isolating high frequency noises. My EI-core does work. It has become particularly important after I had to bypass the Murata EMI filters, but it does get hot and it HUMs when under full load. The humming is audible within a 2-foot range of the transformer. I haven't decided if I should replace the EI core with my R-core to get rid of the humming. But for now, I have learnt to use the humming as a cue to let me know whether the power supply is working under full load of not.
I originally was thinking about building the same linear power supply for my Gustard U12 too, but after I modded my U12 to be fully isolated from USB power, it has become so quite that I don't think an external power supply is needed any more. Now, my U12 and NAD D1050 powered by 0.57uV hand-made power suppy work perfectly. I hear pure, relaxed, sweet and musical sound. This further confirms that an external power supply for U12 is unnecessary, though doable.
Regarding the use of USB isolators, I don't think they will be good for U12 once it has already been modded and isolated from USB power. External isolators can introduce jitter and distortion. I haven't tried them but I am not motivated to try them either, at least not until I am otherwise convinced.
Hope my little report helps.
Now, time to enjoy music!
Cheers
pakultra
