sbgk
- Mar 25, 2013
it has heat sinks on the 4 analogue linear regulators, also heat sinks on the 2 digital linear regulators (X26 iii doesnt have linear regs for the digital PS and doesnt have heat sinks on the analogue linear regulators)I've been researching some DACS. Gustard X30 and X26 III included.
How hot does the X30 get? Is it worth basically Twice the cost of its little brother the X26 III?
it has twice as many transistors as the X26iii for the IV stage 32 instead of 16, so twice the power requirements of the X26 iii
and then you've got the transformers supplying more power to feed these components
there's slightly larger side vents, so expect the case to do the heat dissipation, have seen other dacs with holes in top and bottom to aid cooling
potentially it could get warm or even hot
there seem to be holes drilled on the circuit board between the power stage and the ES9039 chips, presumably to stop heat travelling to the chip
so while the ES9039 chips run cooler than the ES9038 ones there's still heat generated by the doubling up of power conversion components
