Originally Posted by Baines93 /img/forum/go_quote.gif
Would playing without being able to hear the un-amplified strings ring be an issue? Sorry if that is a stupid question!
It's not really an issue in my opinion, but it sounds like plastic most of the times. I can't really recommend it, but it's doable and you can learn how to play guitar that way. I would probably recommend getting a cheap amp and not turning it up too far if you have to keep the volume down. Even cheap amps sound better than the line out most of the times.
Do you recommend getting a sub £70 guitar with strap, bag (no amp) etc, or save for a cheap Fender package (or other known brand)?
I will recommend what I recommend most people who are getting started. Try to find someone with a guitar laying around. There are a lot of people who've got a guitar somewhere stashed away on their attic. Most of those guitars aren't the greatest thing either, but it'll save you the money.
The thing with really cheap guitars is this: You get what you pay for. Which, in case of really cheap guitars, isn't a lot. They won't sound great, and don't care about things like
action.
The question is: Can one learn how to play guitar on one? And the answer to that is: Yes. One can. I did as a matter of fact. I started playing on an old guitar we had lying around and played on it for about 2 years - I was about 11 years old at that time. After that I got a guitar for my birthday which was the greatest thing I've ever had in my entire life. (even though it wasn't the greatest guitar ever) The thing you notice when getting a better guitar is that the crappy one was holding your progress back. (I sure do hope that's a proper English sentence)
So, what I'm trying to say is that when you go for the cheapest guitars, you will probably need another one fairly soon if you decide that you really like playing guitar. That will cost extra money, which no one really wants to spend. Which gets us back at what I mentioned before. Try to lend one if you've got the opportunity.
Because of all of that my advice is: Try lending a guitar from someone and save up for something decent. The only time you will have to replace a decent guitar is if you want a different or better sound - which can be considered luxury.
What do you think of it/them?
Honestly?
What would you recommend as a first electric?
Stratocasters and telecasters are easier to play. Because of that you can mess up your technique because you don't have to place your fingers correctly. A Les Paul would probably be a better idea. Acoustic might be even better, but if you don't like the sound of them I wouldn't bother personally.
Edit: Excuse me for the grammar. I'm not English as (I'm sure) you've noticed by now.
